Wont be able to look at mine as forgot its not home till friday evening. Spectrum list the whole tensioner pulley inc bearings for about £80
Yeah I'm thinking it's the bearings in the pulley! Where do I get the two bearings from without buying the whole thing?
If I remember correctly the pulley bearings are the same as the small flywheel bearings.
Where gonna ring some dealers tomorow and see who sells just the bearings! As don't have time to go to the bearing shop
Off Orange plant and timberwolfs website SKF bearing SKU BE491, 2 needed
Cheers I'll give them a call tomorow! Many thanks
Also can anyone give me advice on how much to tighten them the graph in the manual isn't much help at all!!
I just did mine, well easy mate. I have a spare bolt here, shame you don't I've nearer mate you could of had it.
Did you replace just the two bearings then hodge? How did you get them out?
They came out very easily, I actually put a new pulls on a couple of years back and remember them being an interference fit rather than a pressed fit. They should come out ok mate, get some lube on.
