Botex hydraulic requirement
muldonach
Ok thanks - my trailer has its own pump and reservoir and it is not connected to the tractor hydraulics.
The present pump is tired and is not so far as i can see marked with pressure and flow ratings
cheers
mac
Quite often you see the spool block plugged into the spool valves. Often the operated by the non return stick:lol: Although you do get a restricted flow through the valves but 60lpm will do most stuff. If your doing big butts you might want more than that.
A good hydraulics shop should be able to re condition the pump.
