Hi there,
I need help on how to remove a roller motor on a tw150. Im hoping i can just pull it away from the roller box and start chipper then set rollers going so i can check where a leak is from.
Im sure its the top roller, the roller box slides are wet under that motor etc.
All i can see is 2 17mm nuts but you cant get a socket on them just an open ended spanner.
Just thought id check first.
Many thanks
