  • Replies 20
Yup, I'm a luckey lady. Plan to build something a little more substantial when I have time and just live there. Theres a nice little burn running through and some lovely broadleaved trees. Compost loo and no lecy don't sit to well with my son tho!
I bet your boy loves it!
Loads to explore, and a retreat with character and charm, if the site is secure you could consider off grocery electricity, wind or solar, maybe even watermill from the burn, can be rigged easy enough!
I'm considering a water mill. There are some more cabins- all different about a mile away from mine and solar seems to be the fail safe. There is no stream by those ones tho. I have no money and even less time at the moment so my dreams are on hold until I finish my course and can start full time work!
The watermill sounds favorite, there are some great ideas for them out there & they can be cheap to build with a little research, & great fun to do!
I'm building my camper so I can go stay on my little plot of land when it suits, as well as trips further afield, I'm installing solar panels on the roof linked to a battery bank, which also charges from the vehicle when it is being driven, simple led lights use very little power, & I have a little wood stove for heat & cooking should it be needed.
What sort of van is it? I've always been a fan of the old merc. 709s etc. I've been driving brand spanking new ford double wheel base trannys at work and I can't say there any better despite there youth. I'm a rat look/ banger fan tho so my opinion is tainted!
Yes split charge is the way to go, I use a voltage sensitive relay to trigger a 200amp main relay which then charges the aux battery bank, I have set it to trigger at 13.6 volts, when the alternator is producing, & it drops out at about 13.1 volts.
I like the old vans, have had a few, mine is a vaxhaull movano, I chose it on it's condition, & that they don't seem to 'go walkies' very often, it's actually a nice van to drive, just dont show it a muddy field or you end up living where your stuck!
From the outside it looks fairly modern, inside it's like an old wooden railway carriage, i'm not into modern fabrics & manufactured surfaces, I will pop a pic up when I get more advanced with the build.:001_smile:
I like the old vans, have had a few, mine is a vaxhaull movano, I chose it on it's condition, & that they don't seem to 'go walkies' very often, it's actually a nice van to drive, just don't show it a muddy field or you end up living where your stuck!
That sounds lovely. I think that's the way to go really. You don't want to stand out or look to quirky in a camper once night has fallen. It probably makes the interior feel even more special. I think the muddy field scenario is fairly generic, I wouldn't point the finger at vaxhaull. Would love to see a pic when your ready!
