i got a dolmar 114 it runs but a big piece of the metal under the plastic throttle handle has broken off i can get a SACHS DOLMAR 114 CHAINSAW TANK ASSEMBLY i need to know how to remove the old one and put the new one on how would about how to go about this.
Thats an easy one, I would mosey in the the workshop, put on absolute 80s, dust the tools off and bingo - job done an hour later:thumbup:
It usually a case of taking the top handle off, releasing all the AV mounts, disconnecting the fuel lines and breather/ throttle linkage and then removing the old handle and repeating in the opposite sequence!
Is it the same as this
http://arbtalk.co.uk/forum/chainsaws/33857-whats-your-bench-today-684.html#post1135405
If so I could let it go for a charitable donation.
