pto shaft clutch removal
John Shutler
Ok, comes in four sizes, measure across the tops of two points, ie the widest part of the outer shaft and hopefully should measure 30, 41, 48 or 61mm. Available in usually up to 3m lengths, usually held into yoke by a roll pin. Beat roll pin out and pull shaft out.
Grind a taper on end of shaft before fitting new tube to yoke, and dont forget to grease shafts before sliding together.
