Hi Everyone
I have recently bought a Rayco rg series 2. I have a rough idea how to sharpen the teeth, I have a normal grinder and a diamond grinder for the angle grinder. Does anyone have these teeth and can explain what shape they have to be? or even better have a photo or two? any help would be great!
Thanks
  • Replies 21
As far as I'm aware you have to try to replicate the new teeth, ie a flat bottom and a right or sharp angle to the side of the tungsten.
Personally, it's too much like hard work, I just buy new ones!
Edited by Mountain man
Personally it's too much like hard work I just buy new ones!
I don't know how u afford it mountain man!! There bloody dear them super teeth! I grind them right down ;)
Yeah Saturn knives are best so far that I've found! I just give mine a a quick rub up after every little job!! Never let them get really bad!!
Does nobody braze on new tips?
I found by grinding them down you alter the distance they stick out and change the performance of the machine tremendously,
I used to be able to re braze a set of 24 teeth in the time it took for the misses to cook the tea.
If you buy the tips in the states you can get them for under a pound a piece.
I ran ran two grinders one 66 hp and one 25 hp five days a week for seven years I can't imagine just useing them and buying new when they are blunt.
That's a good shout, I'll look into that.
I had a go sharpening them, found it pretty hard. Do you take your off or do it when there still on?
No keep them on! Drive it up to my work bench plug in my angle grinder and away I go!! I manage to make a set of teeth last me a long time!!!
Hi do you need a special grinding wheel and where is it best to get one from?
