8100 inc vat for 08 tw125? am looking to buy my first chipper.. what things should i look out for when viewing? its from a timberwolf dealer so they should be pretty straight up? or not?
Whats the best way to tell how much work they have done if there is no hour clock?
cheers
not sure about the price as I don't use the 125 , but if your unsure as to accuracy of hours. check everything , anvils, rotor bearings, if it hasn't been repainted look in the hopper ...not much paint means done a lot of work . also the state of the feed rollers can give an indication . best of luck with it . you could also get a reasonable used 150 for the same money though
