I feel these are Ustilina/Kretz (which is it now?)
Crown is perfectly healthy, and weighted towards a property, some 'mechanical' damage around base,
The fungi, top left of picture 4 in the wound looks like it has a bit more substance to it - something desiccated - does anything in particular hang around with Ustilina?
Β
thanks
Dean
Hmmm, more often than not bad news, and a healthy crown isn't uncommon with it. On a sycamore leaning toward a property? Be a brave man who leaves it vertical...
Pretty classic Kretzschmaria deusta. I know, that name still seems unfamiliar. I learned it first as Hypoxylon deustum, then Ustulina deusta. But in following the rules of the nomenclatural code, it does indeed fall into Kretzschmaria, which was published as a valid genus in 1849, although deusta wasn't recognized as that being in that genus until 1970. Oh well, more than you wanted to know!
  • Β
Arbtalk.co.uk is a hub for the arboriculture industry in the UK. Β
If you're just starting out and you need business, equipment, tech or training support you're in the right place. Β If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom,Β Β then you're welcome too.
Γ—
Γ—
