Evening all. My boss has got an old stihl 025. It's ok and runs fine if the saw is level or nose up but if you tilt it down it just drops the revs so quick any ideas
Possible air leak that is made worse by moving the saw, perhaps a short on the kill wire or shyte in the carb.
Worth checking the fuel line isn't split and the fuel filter is situated correctly.
Thanks Spud he reckons the carb is clean and the fuel filter is still good and sat right but I don't think he's looked for air leaks or checked the kill wire
Just stripped one this afternoon which had leaking seals. They seem to be hard on crankseals.
The other thing I would suggest after spuds suggestion of carb clean is the inlet manifold and impulse line. The back handle is separate from the main body of the saw yet both these rubber items are linked between the pair so movement can show up faults/airleaks on these to.
They were the areas that I were thinking of when I said air leak - worth clarification though:thumbup:
