Hi all,
had the Lapse it app (not the pro) on me ipod for ages and keep meaning to have a play.
it would be 1st time playing, so just wondering if anyone else used or had a go with this before ipod/iphone set up,
to start with it would be just for some work shots see how I get on, with a view that it could be running on a screen when at shows
its things like what time settings best and "play back" setting etc
hope you are having/had a good day
cheers:beerchug:
I use it quite a lot for carving stuff.
i tried the profesional version but for some reason i wasnt able to play the resulting movies on my pc, so i went back to the free version
i think i use 2s intervals max resolution, about 30% brightnes (but that was when it was sunny...remember those days?)
i render in MOv with high resolution, 20frames per second
comes out a bit like this: is 2 hours worth of me carving compressed into 2 minutes. practicing for a timed-caring event, part 1
was wondering about maybe 1/2 a day film if not a full days worth of hedging, but then I would need to be a certain distance away to take in all the scene ... or maybe 1/2 day and 10-15-20min each pic little bit of a learning curve I guess, cheeres for info......:hmmmm: sunny days........... do you film with the pod/phone portrait or landscape, if landscape when you load it to the pc can you change layout do you know ??cheers again
Edited by Dorset Hedgelayer
made mistake
