Am rebuilding a TG33 strimmer and the throttle cable is completely missing.I imagine its one of those 90degree metal ended ones that screws into the TK carb.Cant seem to find any generic cables that would do the job.Any help / links appreciated.Its the barrel rotary type carb. Shouldve measured but at a guess id imagine it needs to be a foot to 18" long.Are these carbs and linkages still used today?
Long time since i have seen one of these carbs probably a Niki, the cable at the carb end should have a small barrel nipple, thread throught the cap, through the spring, down the side of the slide, and under the base of the slide through the cut a way in the side of the slide., more like a motor cycle type affair.
Yeh its a rescue job.Home for elderly strimmers but it's so well balanced I want to restore it.Its a TK carb.Seen a few other pics and in some the throttle cable is in 2 stages with some sort of linkage joining the 2 halves.
