As the planning folk and the tree folk often don't talk or even get on, there is a lot of opportunity for stuff to get through that doesn't reach even a rudimentary standard.
If approval is given without a belt and braces 5837 document in place the developer will usually be able to run rough shod over the trees.
Just because the trees are TPO'd, if the plans show an approved building outline, the building generally takes precedence even if it's yet to be built.
The documents for tree protection should be very clear as they have to be interpreted by anyone on the site. It should be beyond doubt which trees are to be removed and those that are to be retained. A topographical plan with clearly identified trees, numbered with tags and a schedule with size, species and works.
If you don't have this, be very wary what you cut. Developers have skin like rhinos and a conscience to match. You'll be the one getting stick from the LA.
Paul is correct, the AIA should be clear (ideally you should be able to give it to someone who doesn't know anything about trees!). It could be that there is a computer error or that the consultant has just rushed something in without first checking. There are a couple of things you can do (without the developer knowing).
1) The report you have will be signed by the author. Find out who it is (should be on the 1st page), give them a call and say you have the report but you are not sure about it and go over it with them.
2) Go to the planning portal (or the LA planning website), type in the address. If there is an approved application for development it will be there, again it will have all the approved plans and related documents (one of those will be the AIA).
3) Unlike what others say, Local Tree Officers are not that bad. If an approval has already been given then they will talk through it with you. If not, as you say the trees are already protected so there will be no further protections.
I would never take the word of the developer alone. I always check with the LA or clearly show it in the report that no checks have taken place. Developers just want the houses built and on to the next project. If they drop you in it, don't expect them to come to your rescue!!
