I'm after some advice I know the figures can only be a rough guide but...
I'm wondering how much wood it would take to run an 8kw stove through winter
Open to hardwood / softwood options
Burning for about 8-10 hrs a day
Cheers
Assume 4 KWh/kg so a 8kw stove should use about 2.5kg/h allowing for some inefficiency
So burning 10hours a day then 25kg/ day
Hard or soft little difference in weight used just need to feed it more often with softwood as less dense.
Last winter I got through 4 wood bays which were 1.2m deep, about 1.5m high by 2.8m wide packed with three rows of logs (gaps between).
I forgot to say that my stove is a central heating model, about 14kW output
