The knob is held on by a little pointed grub screw, it is possible that the knob is turning but the grub screw has cut its own ring around the threaded shaft. Find the grub screw and take it out, pull off the knob and replace it with two nuts which you tighten together. Then use a spanner to adjust flow.....
  • Replies 21
