Loler Thorough Inspection, advice wanted
Keithrturner
I have been informed by a reliable source that it is ok to LOLER your own kit "in house'. However, it is advisable to have an outside inspector carry out checks say every 4th or 5th time. Also, a good audit trail of kit being purchased and records of kit being retired would prove due diligence and impartiality.
Thanks, Timon
Here is the low down on this topic
Yes you can do your own but in the event of an accident your procedures will come under some serious scrutiny.
What is a 'competent person'?
The term 'competent person' is not defined in law but the LOLER Approved Code of Practice and guidance (paragraph 294 on competent persons) states that:
'You should ensure that the person carrying out a thorough examination has such appropriate practical and theoretical knowledge and experience of the lifting equipment to be thoroughly examined as will enable them to detect defects or weaknesses and to assess their importance in relation to the safety and continued use of the lifting equipment.'
Although the competent person may often be employed by another organisation, this is not necessary, provided they are sufficiently independent and impartial to ensure that in-house examinations are made without fear or favour. However, this should not be the same person who undertakes routine maintenance of the equipment - as they would then be responsible for assessing their own maintenance work.
Thorough examinations and inspections of lifting equipment - Work equipment and machinery
