Well I have a couple of tanks through mine now, it is a strong saw in the cut, plenty of torque, yet revs well, & I expect it to improve with a few hours on it, & have high hopes of it being a competitive, reliable saw.
Mine came with a 20 inch bar, they will take a 25 inch.
The clutch cover is alloy.
It has double bump spikes.
The balance feels spot on, certainly not nose heavy, so a bigger bar I suspect will feel at home on it.
The air cleaner is easy no tool access, & good quality, so easy to clean.
The bar on it is of nice quality too.
Over all the build quality looks & feels very good, I would say as good or better than the big 2 brands, and it runs a normal carb, so tuning will be a breeze, it has plastic restricting caps on the H & L screws, easy to remove them for the exhaust mod brigade, ( which I understand these saws respond well to).
Sorry to bore the carp out of you, but for what it's worth, I am a happy bunny with the saw in all areas so far.:001_smile::001_smile:
Hi,
Well done, sounds really good, particularly the 'normal carburettor' & build quality
Keep us posted on how things go, no daft flippy caps either?
N
Edited by NFG
No flippy caps, big fat old school ones, & will take a combi can spout.
The oil tank is in alloy, with a paper type gasket, the petrol tank in plastic, same colour as the saw, but you can see your fuel level through the plastic.
marvellous piece of equipment,end of :thumbup:
I used it today logging up a few loads of mixed wood, three more tanks through it, on Aspen, it is running stronger after a bit of use, I also had to knock the tickover down a bit, as it picked up as the saw loosens in.
I will be very interested to run it alongside a 560, I think the husky will cut a little faster, but it will be a close run thing imo.:001_smile:
SPOT ON :thumbup::thumbup::thumbup:
felling pops all day with mine alongside my 372,both 18" bars,if you blindfolded me it would be hard to tell the difference in torque,the 620 is that good believe me
I know I'm harping on, but it really is a lovely saw, reminds me a bit of a smaller version of the Stihl ms460, but with a more refined build & handling.
A high accolade indeed.:biggrin:
