I'm after the frame or the chassis (no idea what you want to class it as), for the 550xp. If someone has a stripped 550 and doesn't know what to do with the left over carcass, let me know because I cant find one anywhere to buy!
The bit that has broken on mine, is the part where the chain brake handle meets the frame on the right side (bar side). The actual frame has cracked off and the brake no longer works...
Hopefully someone out there has one! I've been looking for ages!
Thanks
You can only buy the 2 halves as a set, and at £300, you'd be better off buying a new saw, but try spudulike on here, I know he's just built one from 2 dead saws
Nothing here, I just happened to have a failed saw that wasn't worth the cost of rebuilding from bloke "A" and bloke "B" with a decent top end and the rest of the saw with buggered chain brake mounts only two days old.......was interested in his dissasembled saw, a deal was done between the introduced parties and bingo - put a worker together from the parts.
I don't know of any going and it looks like a waiting game TBH as it was in Mr "B"s case!
