  • Replies 33
If those bolted up rights get too loose, get a long 12mm drill bit, drill through the entire unit and use threaded bar instead of the coach bolts/screws, what ever you have used. Then bolt on from both sides and clamp together.
I used coach bolts as recommended.
I will hopefully get a video or pic of it in use, and if the uprights starts to spread I will try the threaded bar.
Thanks
Husqvarna
