can anyone tell me why my saw keeps cutting out when i apply the chain brake:confused1:
Centrifugal clutch springs weak or broken, or clutch drum bearing locked up.
Check & grease the bearing, could be your problem, as the bearing should spin when the saw is at tickover, & the chain/ clutch stationary.
with the chain off the clutch drum should spin freely if you give it a flick, ( engine turned off).
Was the chain spinning at idle before you put the brake on?
I am actually a fan of the lil 330. They are great saws once tuned a bit.
