Bit of a short notice change in a job spec means I need to off load up to two 3.5 t canter loads of woodchip in Clevedon. If any one can help out I would be very grateful and can always return the favour if you are working around the Taunton area. Thanks Colin. :thumbup1:
Hello Sawman, my relative has agreed to take your 2 loads of woodchip. I will send contact detail via PM so that you can contact him directly for the address etc. The power of Arbtalk :) (Thanks Steve B)
Hi Colin, I will assume now that you no longer need a place near Clevedon to drop your chip but it would be good if you could confirm one way or the other, thanks.
Apologies Steve I didn't see the recent messages. We managed to remove the woodchip back in one load after all. Client didn't want as much cut as first expected. Cut a long story short it was for a subsidence issue. Sorry for late reply. Colin.
Read more
