Hey everyone, having recently acquired a rural property, I would like to add onto an existing shed that is already on the property. Keep in mind that I did not make the original shed, but it still looks sturdy to me. It is structurally sound is what I am trying to suggest.
I want to add a freestanding structure as my new addition. I intend to use trim work to marry this new addition into the older existing shed. Considering that both roofs have a different height and pitch, I have been told that this is going to allow the overall design to be much stronger and much more more rigid.
I would like to use my new shed (or improved shed, however you want to call it) as a storage space for some equipment and use it as a workshop. Is there anything that I need to know about that I might not be considering? I consider myself somewhat handy, but I am no carpenter, contractor, or house builder.
If there are any factors that you think I should be paying specific attention to, please do not hesitate to let me know. Thank you for any suggestions or hints that you might be able to give.
Think big!
Consider removing existing shed and bunging up one decent coherent (steel framed )unit.
Agric spec steel type SHOULD be cheap/affordable.
Steel/tin roof and timber clad walls perhaps.
How tight is your planning likely to be.
Will the neighbours be likely to "grass" you up
I like sheds btw.
One can never have enough sheds, or big enough sheds.
Photos please.
Marcus
Gather info like how long your existing shed has been there and any proof if possible. Take photos of everything before you start especially if you knock it down.
I have built sheds on a budget but in hindsight wish I had coughed the money for a proper job.
