As i said, was a mix of that and guess work :) on the bench it lasted longer, of course, but i did use it once almost flat out cutting small firewood, and the 180 lasted a good 30mins, I think a bit longer.
As for oil, I refill after changing the battery 2 or three times, and there is always some left over. Just keep an eye on it and don't forget.
Is there a timer on the saw clocking trigger time?
On the Husqvarna 536 there is. With the cable on your computer you can see the runtime and standby.
Battery runtime is highly underrated!
When you use the saws only for pruning you can easily manage your work between coffee breaks. Going up again I throw in a new battery and when you bring the charger the not even flat one you took out is charged up in no time.
Wolter
