Entec 150 blades
hamdogg
So I don't have to worry about re setting anything when I replace the blades?
make sure you clean all the crap out of the torx head ,or youl nacker them then is a drill out job,
remove the springs on the roller box then lift it up & wedge a lump of wood under it it makes for better access to the blade pocketys
