HI ALL. I was hunting of the correct Mi for my Sons Mini Moto, and found a thread on Stihl web site saying
When using STIHL 2 stroke lubricant:
Mix at 50:1 (20mls oil per 1 litre fuel)
When using any other brand of air cooled 2 stroke:
Mix at 25:1 (40mls oil per 1 litre fuel)
I am not using Stihl oil and have been running 50-1 should I change to 25-1 ?
I have a mixed set of tools. ChainsawsMS201,241,MS150 plus the Blowers,Strimmer etc..
thanks for any advice..
HI MATE I USE GREEN STIHL 2 STOKE OIL thanks but ask others thanks jon :thumbup:
Use whatever mixture ratio recommended by the OIL.
What oil are you using?
have used good hi grade garden machine oil before ..cant remember the name or Rock oil (smells nice) and R40
Andy
As a general rule the semi synthetic and fully synthetic oils are 50:1 and the mineral oil is 25:1. Although that can change depending on the machine and the brand of oil. But if you are using a oil that is the same spec as the Stihl oil then mix it at the same ratio.
