Can anyone tell me if there is a British Standard for semi-mature tree sizes? BS3936 part 1 only covers up to extra heavy standards, The national plant specification gives sizes for semi-mature, Barchams claims that semi-mature are in BS3936 but not in my copy apparently.
So to clarify; is there a standard for anything over 'extra heavy standard' at 14-16cm girth?:confused1:
No idea! Maybe you could send a message to Barchams and ask them to clarify. All the suggestions are that the definitions are from 3936 1992 but if you've looked at it and drawn a blank I can't think of anything else.
Found them all in the HTA up to 50cm girth, semi-mature. 3996 definitely only covers the smaller trees (extra-heavy), there's nothing in the 'nursery to establishment' either.
I'm trying to correlate all the standards into one table but its a pain in the proverbial.:001_rolleyes:
Have you tried 8545? - Trees from Nursery to Environment?
I can't see anything flicking through, but its 97 pages so there might be something
From 8545 : DBH at 1m (in cm)
Standard - 8 to 10
Selected standard - 10 to 12
Heavy standard - 12 to 14
Extra heavy - 14 to 16
Also I just noticed my copy is marked as a '2013 draft'. I don't know if there is a more recent one. Let me know if you'd like a copy.
Standard - 8 to 10
Its out now:thumbup1: The HTA /National Plant Specification goes up another 11 categories - to 80cm girth, the 50-60cm girth are specified as 1000 litre pots:biggrin:
Think the BS might be a bit behind the times, there's no sizing in the BS8545 but it's a good read.
