end for end splice to make a prussic loop ?
vladimir
Does any one have any thoughts on and end for end splice to make a prussic loop. I was thinking of using a brummel type splice to make a prussic loop out of some ice tail or even arom pruss. But ive never seen it done before. apart from maybe the Roop slings ?
Also though it could be quite neat on armor pruss if you pull the cover over the splice so it cant be seen , or exposed to any heat or friction.
Is the splice suitable for this application ?
Not sure but won't the splice change the characteristics and handling of the prussic and ultimately its safety?
A double fishermans knot though ungainly and bulky at least is obvious enough not to be positioned wrongly.
Correct me if you think I've missed something here.
the end for end splice is perfectly good for a fishermans loop- just make sure the splice is on the leg when tied. i probably wouldnt try Ap as the core is very non heat resistant. ive made a few out of icetail, just do a long bury. Samson instructions are the best to follow
