As i recall the 1100 and the 2100 had a red Femsatronic one peice electronic unit, this was replaced on the 2101 to a black SEM unit, at the same time the flywheel was changed to go with the unit, the black SEM unit was also used on the 480 and the 265RX, unfortunatly the flywheel was different from the 480 amd 265 due to having three starter dogs rather than two, if you can get the later unit and electronic unit you can retro fit it.
Unit part no. 501831901 flywheel 501832201
i was told all of the parts are NLA which is what i thought so if anyone has a coil kicking about or even a broken saw i could buy for spares! (with a good blue spark!)
Charlie
