Don't mess with it without putting a gauge on it - you could do more harm than good! Contact Jez Smithers at TS Industrie/Eric Hunters for the pressure settings and go from there.
Hydraulic psi on a GreenMech is no more than 3000 for most models. Over period of time the blow off valve may weaken and drop to, say 2200psi and a tweek back to 3k makes the world of difference! This reset is always carried out with a good set of gauges that are known to be reading true as over pressure could pop seals etc.....
