Sign in to follow this
forest tink
stihl x fit trousers
In reply to original question, i"m a 34" waist but seem to have slightly larger thighs and i needed the XL to go over them, I tried the L and they looked like they had been sprayed on! the waist on mine is too large but i use the braces and belt approach. They are by far the best trouser i've had, In 19 years of tree work without doubt. IMO
Hope that helps
Share this post
Link to post
I have just recently brought a pair I am 32 waist so I got the small, they fit perfect for so if I was you I would go with the larger size as they are quite tight fitting.
Share this post
Link to post
Agreed, they are close fitting!
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Note: Your post will require moderator approval before it will be visible.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
