If it's a new saw , just take it back ... You have spent a lot of Money and your dealer should fix or replace the faulty part or saw....
Thats about it really . I agree .......
Hi,
It sounds as if the oil channel from the pump is not mating correctly with the supply hole on the bar. this may be because its mis-aligned or there is something lodged between the casing & the bar or the bar securing studs are loose (unlikely) causing the oil to seep out.
As its new, I would return it.
N
Edited by NFG
