How to post a Youtube Vid?
GardenKit
  • 1 month later...
Had a similar problem.
To get a "sort" link, click the "Share" link under the video (next to the Like link).
That link starts with a http and uses the youtu.be host.
Now, I'll just paste the link straight into the text field here...
=EDIT=
Well that did NOT work, now I will try using the link straight from the browser (on http://www.youtube.com) and remove the "s" from https...
[ame]http://www.youtube.com/watch?v=qk2QtwoG3J0[/ame]
Edited by morten
I suspect you may also need to use "Go Advanced" button below the text field in this forum when posting links that should be interpreted and embedded.
This posting is made in "Post Quick Reply" mode ("Go Advanced" button showing), and I will try posting the same link (from the browser, but with the "s" removed from "https")...
[ame=http://www.youtube.com/watch?v=qk2QtwoG3J0]Husqvarna T540xp v Stihl 201t - YouTube[/ame]
=EDIT=
It turns out it does NOT matter whether you post the link in Quick Reply mode or Advanced mode after all :)
