Whats the difference between;
- Husqvarna XP 2 stroke
- Husqvarna Low smoke 2 stroke
- Husqvarna HP 2 stroke
Which would be better to use,
currently only using my saw couple of times a week, but looking to go more full time at a later date, so want an oil that would look after the saw (Husqvarna 357xp)?
Or are the cheaper 2 stroke oils just as good?
Are all chain oils the same ie the "cheap stuff" compared to the named stuff from Husqvarna and the like?
Huge amount on this already . If you put in a search You will find it ." What oil " "Which 2 stroke " etc . Just quickly though synthetic at 50 : ! :biggrin:
