2 stroke mix ratios
Tommy Noddy
I wonder if anyone can give a definitive answer on this. Common sense would suggest that 25;1 fuel/oil mix would give greater lubrication than 50;1. But I seem to remember from my biking days the manual saying "adding a bit for luck" would make the engine run lean and overheat. Not so common sense after all perhaps:confused1:.
Any thoughts ?
