'ello
When using the 880 in big oak, the filter gets clogged far too quickly in my opinion. I have used a piece of stocking around it as a pre-filter, take spare filters out with me etc but these measures do not address the problem.
The problem as I see it is that the filter just gets exposed to too much dust by design.:sneaky2:
So, if the saw is used in an Alaskan, I wondered if anybody had attached an external filter to the saw.
I'm thinking a mill-mounted (in the middle, least dust?) fairly large filter connected to the saw with a flexi hose and attached with the normal filter screw connection so it's easy to take off.
Any thoughts, comments, experiences appreciated.:thumbup1:
I only find the air filter gets clogged when I'm doing the lower cuts on a trunk and I'm close to the saw dust pile. Never had a problem with clogged filter any other time.
However I can see what your getting at but not sure the engine would be pulling in enough air from that distance.
