Makita 4 stroke back pack blower
monkeymoreton
If it is not reving fully the first thing to check is the fuel system. You have done that so now check the exhaust, it is possibly blocked. Blockage could be in the spark arrestor, the exhaust box, or the exhaust port.
If its a fourstroke, check the valve clearances.
It is 4 stroke when you pull the trigger fully in it bogs down and dies out I'll clean the exhaust this weekend. It has been run on 2 stroke by people at my company
Sent from my GT-I9300 using Tapatalk
Some of them need two stroke mix - they are fourstrokes bu not as you know them - typical fourstrokes have wet sumps - oil in them or an oil tank and scavanging system - Dry sump.
The Stihl ones I have seen are the spawn of beelzebub and run on two mix!
