Hey, I cant really answer your exact question as I havent used one on the ground but I have used one in a tree a few times and found it a really useful bit of kit. your not going to be able to get back leaners over with it but when the weight is dead center when felling out a top or when blocking down larger sections are two situations I found it most useful in as it gives a significant amount of lift and its pretty easy to use.
Got given one a while a ago, no good for on the floor but can be handy in the tree as long as the handle does not come off at the crucial moment. Used it to block down some long heavy oak lumps the other day, just makes it a bit easier to get them to topple of the pole.
Used the k&h triple not a bad wedge for the price. Been using hard heads but even they snap. Maybe it's time for hi lift plastic inserts!!
Are they the hardheads with the metal cap? If so, where did you get them, only seen them in the US?
Sent using Arbtalk Mobile App
