Hello,
I have a Stihl 070 one of the old Geman ones, not quite sure of the age. Basically the pull cord is coming out as it should, there's a lot of resistance and it doesn't re-tract very well. Can anyone explain this?
Anyway, the FM starter is quite easily jammed if re-assembled wrongly, it should be the rewind spring attatched to the rope guide, then a thin metal washer, plastic washer, rotor friction arms, plastic washer, metal washer, spring, big metal washer and an e-clip, if anything is missing, it doesn't work
Sent using Arbtalk Mobile App
