Rich2484
Dan Earp
Hi arbtalk lads and lasses, just wanted everyone to know if you haven't read the 'whats on your bench' thread,
That rich2484 took on my broken ms260, which sounded easy enough at first but had some hidden issues. He kept me up to date with everything, took the time to explain when i didn't understand. An excellent service and the saw is running great once again 👍
Should anything breakdown id happily use Rich2484 time and time again.
I also used a company called ipostparcels.co.uk or .com and pick up/drop off from leicester to dover was £8.99 next delivery. They kept me up to date and will also use them again. Makesure u have a printer as itll dave u £1.50.
So if you need someone to look over/fix etc a saw or anything else have Rich2484 in mind
Cheers dan
Cheers dan
ill second that dan
He is very good with machines :thumbup::thumbup:
