I can't open the pics on your link.
But you will find the clutch drum and bearing in the cone shaped bit that joins the shaft to the engine.
If you take the drive tube off first, then the cone shaped bit, you will find the clutch drum inside. If its firm and spinning freely all is well. If its flopping around or very noisy when it spins, it needs replacing.
