A member on here is after a different sprocket for this saw ie. 3/8 lo pro or 1/4"... to run a carving bar....
Anyone know if this saw takes the same sprocket as any other older model saws?
:001_smile:
The same as a 440e if that helps? 435, 440, 445, 450, 455, 460 range.
crank shaft diameter is 0.472
Not sure if the code csr14 helps but that's the 1/4 drive sprocket a big American supplier uses ;-)
Ha ha - good work - baileys have them I see...
Oregon rim sprocket - very handy so then 3/8" lo pro and 1/4" are options...
....put that into oregon webshop - invalid material number!
Not available in the UK - I will get onto it!
:001_smile:
Woodland international Mpn: RSM-250-9 may also be a helpful code?
Thanks - I have an account with them - this will be a re badged oregon sprocket so if I don't have any joy with Oregon UK then I will see if I can get a load over..
:001_smile:
Been a bit thick here...
Part number is 36868X
So oregon do have them in stock as as well... I have ordered a load and then change the rims over to 1/4" or 3/8" lo pro.
Will put some pics up here and also list them on the website here in the carving sprocket area Carving sprockets
:001_smile:
  • 4 weeks later...
Hmmm - got a load of these but they have the 3/8" standard rims on them... (rims come in small and standard spline sizes)... so the smaller 1/4" rims do not fit on them...
