If you just made the frame out of steel and sheeted with plywood it would be alot cheaper and lighter. Most of the weight of the canopy was in the sheet steel
Good thing about plywood for the sides is once they start to rot out you can easily unscrew and replace.
I just cut down a £300 transit tipper body, it was complete with the hydraulics and motor. if you get the Ali one it all comes apart easily and cuts down with a hard point saw. I never bothered with the chip box because we sometimes need it as a pick up , we just have two tatty old bits of ply bolted in ( must change them they look hideous). It will carry a ton if the weight is pushed right to the front.
Bob
  • 2 years later...
Hi mate
Ute looks Mickey Mouse
I have a 2003 TD 3ltr Hilux and looking into converting it to a tipper bin etc
Was wandering a few things
* how does it handle towing a chipper?
*how does it go towing a chipper with a full load of mulch
*any problems with stock suspension on ute?
*braking issues?
*how is it looking now 3 years on?
* any major mechanical because of the bin and or towing a 6" chipper?
Im located in Melbourne and I can't weld
If you are interested in building me a canopy or directing me to someone who can that would be great
Hopefully speak soon
Kind regards
Peter
[email protected]
What clearance have you guys left from tyre to base of bed?
Need to do something like this to mine in the new year but struggling to work out heights other than existing tub height
Because the tipper frame bolts on top of the chassis the tipper body is nowhere near the tyres even when loaded/overloaded. I would recommend uprated springs though.
Bob
HD springs on the Navara tipper , that s a ton in the back
Edited by aspenarb
fat fingers
