I'm changing to Greenteeth now as run out of finger teeth and the pockets need changing as well, do an opportune time.
What is the best configuration, an angle and a straight on each pocket or just angles and no straights at all?
Cheers.... Al
Thanks for your reply.
The reason I asked is because I know some people do away with the straight finger teeth altogether. Just wondering if the same setup works with greenteeth or straight ones are needed.
I've always wondered this. I've got a little carlton and always just put them on randomly, anybody know where I can look up the correct configuration, or what works best for otheres?
There are lots of different configurations & each manufacturer has their idea of what works best, if you call 01636594360 & press 2 for parts they will be able as an official Greenteeth dealer to tell you the set up for your model.
