MS260 - which replacement tank housing?
hardtop110
Hi folks - after a little accident with my saw today I'm the market for a replacement tank housing for it :blushing:
It has a part number on the bottom - 1121 791 1003, but a search of the parts catalogue suggests that 1121 350 0829 is actually the correct number.
So I've seen this on eBay - STIHL MS 240 / 260 REAR HANDLE / FUEL TANK ASSEMBLY NEW | eBay
Do you think this will do the job? Anywhere else worth looking for spares?
Thanks in advance.
At that price it's cheap enough to try
I could be wrong but the Stihl part number is probably for the bare tank only that will be a pattern part and looks like complete assembly with tank vent pipes etc so worth a try
Have just ordered one of eBay for my 660 as the stihl part number was bare plastic casing only at £70 + vat whereas complete assembly inc postage was only about £40 for pattern part just need to wait for it to arrive now
Sent using Arbtalk Mobile App
Would your little accident have been like the one my 660 had that where a tree ended up on it and won the fight
Perhaps! :001_cool: Its mad up here today. Managed 3 ranger loads of firewood scrumping before I bit off more than I could chew with a large beech limb.
Just need to get it back up and running as there is still plenty of 'clearing up' to do!
It will be a Chinese part bought in large quantity by an UK seller, sometimes cheaper to buy off the Chinese guy on ebay and have it shipped from china. I suppose plastic parts should be ok, any other parts i would be wary of. I'm considering buying a Chinese crank for a MS361 as i cant find a good used one anywhere and i've had the saw in bits for a year.
0834 is identified in the 2012 parts catalogue here http://www.lsengineers.co.uk/media/pdfs/stihl/MS260.pdf as the correct number
0829 is identified in an earlier 2009 parts catalogue here http://www.keepandshare.com/doc/2061856/ms260-ms260c-pl-pdf-july-12-2010-12-24-pm-508k?da=y
So it's not clear which is the correct one, but as my saw is pre 2012, my money is still on 0829 - fingers crossed!
