Over-hot cylinder, rpm correct. Ideas?
riverdog
is there a cold running switch over plug in the air filter cover like the254 xp? as if shut will make it run hot in this part of the world.
Good thought, but the hole should be plugged not open. It stops the hot air from the cylinder coming through to the carb.
Sent using Arbtalk Mobile App
The hole should be covered/plugged, as it will put hot air through the carb, which would cause it to overheat
