Right - back home now and from the IPL, I can see that part 1122 400 1203 is the correct part, the part 1122 400 1207 is the part for heaated handles and will have a circular magnet on the back of it. You are correct about the winding being for the heated handles.
There are quite a number of coils listed: -
1122 400 1300 (must be used with 1122 400 1201/1206 flywheel)
1122 400 1303 - From Part number X 18 761 250
1122 400 1311 - From Part Number X 31 067 164
0000 400 1300 - From part Number X 31 067 164
The latter three part numbers are to be used with 1122 400 1203/1207 flywheels)
I think your coil may be aftermarket and has no retardation on low revs at start up - this is what gives many old saws a real kick on starting as the engine fires on the upward stroke ripping the starter out of your hand - the ignition was set at around 19 degrees advance with no electronic retard!
Try to get hold of the 0000 400 1300 ignition module and try that. One simple thing to try is to increase the distance of the coil to flywheel to say "double business card", check the saw still sparks and try that, it will have the same effect as retarding the ignition but may cause lack of spark issues!
Sorry spud, already sent him the IPL and workshop manual
Sent using Arbtalk Mobile App
  • Replies 21
