Been asked to reduce ash and this was at the base...its a tpo tree and when climbed in to crown a few limbs where hollow. The tree its doesnt look great and spans over 2 gardens. The council want it reducing but I think it needs to come out? If it is what I think isnt it a secondary fungie? Any advice would be great?
It sure looks like Pholiota squarrosa. Whether or not the tree needs felling depends on how advanced any decay is.
If the tree has a TPO it would be reasonable to expect it to have a decent amenity value, so rushing in to fell it may be a mistake. Can you investigate the base to quantify how affected the tree is? Perhaps get someone along with a resistograph, or have a tap around the base with a mallet.
As you will know, Ash will take a good hard pruning so it may well be possible to significantly reduce the tree to reduce the likelihood of it failing and then manage it as smaller tree/pollard in the future. Hard to say without pictures of the whole tree and its immediate environment.
Im with Paul on this one, P. squarrosa can be a very significant problem on Poplars for example but on ash far less so, but that statement of course needs confirmation in each and every case as always.
