Well I got the camera out. It may be little late for the OP, but could help others.
+Garden . That is an good vid and shows everything perfectly . I knda new it already but for any one who is having problems it could not be better . Thanks .:001_smile:
Good vid, an Eaisier way to take the chain break off is to push it off using the handle, although the casing will not fit on as the break is on if you push the top bit on the chain break handle you can pull the handle to release the chain break, next time I take the side plate of il do a video as I can't really describe it :)
Sent using Arbtalk Mobile App
I know what you mean , have done it that way . Also spun the clutch right off put the cover on snapped the brake off and then put the clutch back on . Bit of a faf but works .
