Im trying to understnad what makes a timber quality Larch tree
DBH around 40cm
TD from 15cm upto around 40cm
Straight.
How straight to they have to be. Dead straight, or are is the odd kink allowed
for example some of the trees I have, have flaws around 18m up.
At what height are forks ok ?
Cheers
eurof spec is 18 minimum top u/b for a 3.7 sawlog; used to be 1" deviation per metre but not so sure about that anymore and ample knots are a no. Had a heap of logs last year; firewooded the lot in the end as they were borderline rough and mill rejection was not an option!
3.7m log 18cm+ tdub
4.9m log 18cm+ tdub
4.9m log 30cm+ tdub
7.4m log 30cm+ tdub
Edited by TimberCutterDartmoor
25mm per 1m of deviation from straight . No double bends no knots >25mm and no rot or pockets of rot.
Remember it's not just saw logs in a tree there is pulp, chip, pallet, shavers, fencing. All can come out of the tree you just need to have someone who wants it and in a quantity that they want it.
If in doubt cut to the next spec down as the last thing you want is the expense of a rejected load:blushing:
:thumbup1:
