Ash you have exceed your PM's. Do you want to pop up to my place and have a look at my kiln set up ? I can then nip down to yours and help you get yours working properly. I see you are only using one heat exchanger which is not going to help airflow. I have a couple of exchangers you can have ( FOC ) which will help get it on the right track. PM me.
  • Replies 22
vents at the bottom ie ground level, not at the top ?? yes.?
Yes hot air rises so the vents need to be at the bottom to help keep the temperature in the kiln
